Removal Voicemail extra
- Home Phone
- Removal Voicemail extra
20-02-2015 10:37 AM
Would someone please extract their digit & remove this unwanted feature. Thank you.
Nick
Re: Removal Voicemail extra
20-02-2015 10:54 AM
"The development team will fix the issue as soon as they can. Obviously I hope that's sooner than later."
I have also been promised refunds for overcharging which could run on for months. I am totally unimpressed by such awful service.
Maybe someone on the PN forum staff may be able to get this sorted in a shorter time period...................PLEASE!
20-02-2015 11:06 AM
The changes on our side will take longer as it requires development work, but that is only in relation to cosmetic detail, and possibly billing. The service itself should be simply the above. If you are still showing as 1571 Extra, please listen to all your messages as with your permission I'm going to switch 1571 off altogether, and then re-add it to try to fix the issue permanently.
20-02-2015 11:12 AM
Thanks agin for your prompt response.
20-02-2015 11:33 AM
20-02-2015 11:37 AM
20-02-2015 12:20 PM
20-02-2015 1:13 PM
20-02-2015 2:59 PM
23-02-2015 11:11 AM
23-02-2015 5:22 PM
For our reference, to save loading the account, it's been raised as task 433202.
24-02-2015 5:27 PM
25-02-2015 12:22 PM
25-02-2015 12:44 PM
17-03-2015 8:31 AM
adie:quote
