Reducing Credit limit
- Home Phone
- Re: Reducing Credit limit
02-03-2016 11:44 AM
is there a way to reduce my credit limit for my home phone? We have evenings and weekends package and it;s currently set at £55 Buffer, but i don;t want to go anywhere near that amount, ideally i'd like it set to £3-£5 maximum.
If it can be changed please advise how i do so as there is no option on the website that i can clearly see.
Many thanks!
Many thanks!
Message 1 of 6
(1,920 Views)
5 REPLIES 5
02-03-2016 11:56 AM
You will need to call PN or use chat and request it to be lowered
kind regards
Mike
kind regards
Mike
Message 2 of 6
(1,062 Views)
02-03-2016 11:59 AM
It's also worth bearing in mind that with low amounts around £3-£5 as you have said, it could be easy to run in to the limit. If the credit limit is hit and call barring is applied, a £5.76 call barring charge would be applicable.
Message 3 of 6
(1,062 Views)
02-03-2016 12:03 PM
Thanks guys!
Some good information there!
Would you not get a warning that you were close to using your buffer?
I don't plan on using it outside of the evening and weekend times to UK numbers only.
Message 4 of 6
(1,062 Views)
02-03-2016 12:19 PM
You should certainly get a warning email when you get close to the limit, however as call data isn't recorded in real time it could be easy to pass £3-£5 of calls before the email is actually triggered.
Message 5 of 6
(1,062 Views)
02-03-2016 1:34 PM
Thanks Harry! Good point i understand.
Message 6 of 6
(1,062 Views)
