Recent calls...
Peterworks
Recent calls...
My 'recent calls' has not been updated - last shown is 31/10/13.
I make quite a few calls to Spain so need to know how many minutes I have used almost on a daily basis.
Is there a problem ?
Peter (User PSU33)
12 REPLIES 12
orbrey
Re: Recent calls...
Hi, looks like it's starting to catch up - I can see a call from the 4th on there?
Peterworks
Re: Recent calls...
Thanks Matt,
Will monitor but looks okay now.
coastergrotto
Re: Recent calls...
My last calls are showing as 28th October.
coastergrotto
Re: Recent calls...
Still no update of my recent calls.
coastergrotto
Re: Recent calls...
Updated this morning so all is good.
reserved
Re: Recent calls...
I've found in the past that sometimes they are several days behind and other times they are up to date.
I assume the info relies on bt passing it on!
grahamt
Re: Recent calls...
My last 'recent call' is Wed 6th November. I certainly made a few calls over the weekend that should have shown up by now.
Graham
Peterworks
Re: Recent calls...
Mine have slipped again - last update on 6th November.
This happened a few years ago and took ages to resolve. Looks like the gremlins might be back.
Come on PlusNet, if you offer this as a service then it should work properly !
BenTrimble
Re: Recent calls...
We're working out one or two small things and are a couple of days behind at the moment, we should be back up-to-date pretty soon, maybe by tomorrow morning.
Peterworks
Re: Recent calls...
Thanks Ben
reserved
Re: Recent calls...
My last calls shown are from 6 November.
BenTrimble
Re: Recent calls...
We're now up to date, please re-check your itemised bills and if there's anything missing, please bear in mind that delays of up to 7 days are not uncommon.
