Recent calls not updated
- Home Phone
- Recent calls not updated
Re: Recent calls not updated
02-03-2010 8:43 AM
Quote from: Bob AFAIK call processing was about 2-3 days behind but running as expected. I ll check tomorrow to make sure there's nothing untoward happening. Probably also worth me mentioning that we've plans to refactor the call processing systems at some point in the not-too-distant future.
My last call showing is still 23 Feb. so it's about 6 days behind. When it's that far behind it loses some of it's usefulness so let's hope the refactoring improves things
As far as I can remember the call data when I was with Greenbee was far more reliable.
02-03-2010 10:14 AM
Quote from: reserved As far as I can remember the call data when I was with Greenbee was far more reliable.
Greenbee & Plusnet use the same call processing systems AFAIK
Anyway, I'll do some digging this morning and report back as soon as I know more...
Edit: I've had a developer check the back-end systems and things are about 1-2 days behind *in terms of processing* i.e. you may still have calls from before this that have not yet appeared on your call itemisation. The unprocessed records equate to about 266712 calls. The system does not look at call records on a first come first served basis, it simply selects a customer's phone number and processes their calls. The ordering it does this in doesn't follow any specific logic either.
Call processing is slower that it has been in the past and until we refactor it I don't personally think it's going to get much quicker. This issue will have been compounded over time as well due to the steadily increasing customer numbers.
So in a nutshell, there aren't any problems per se, however this kind of thing is probably going to happen from time to time until the refactoring of the call processing engine.
02-03-2010 11:32 PM
03-03-2010 7:41 AM
03-03-2010 1:16 PM
| 2010-02-22 | 4 |
| 2010-02-23 | 29 |
| 2010-02-24 | 18 |
| 2010-02-28 | 165279 |
| 2010-03-01 | 96070 |
You'll notice there's a fair few to get through from the 28th. Bear in mind that this is the date the calls were added to our database and not necessarily the date the calls were made. For that reason it's entirely plausible that these missing calls from the 23rd/24th are in the batch that were added to the database on the 28th.
03-03-2010 4:32 PM
03-03-2010 4:47 PM
Full Fibre since September 2023
Mac OS14 and Firefox user with latest versions of both
03-03-2010 4:50 PM
03-03-2010 5:51 PM
03-03-2010 6:25 PM
dick:quote
03-03-2010 10:53 PM
I did get the back-end databases checked at a day or two ago and it wasn't indicative of problems, things are just taking some time at the moment
04-03-2010 10:01 AM
22-03-2010 8:55 AM
22-03-2010 9:34 AM
22-03-2010 9:36 AM
