Re: Not receiving incoming calls 2
mf50bh
When I call my number it says service unavailable.. Check number and try again....I can make calls out on the line and line checks have been done all good so why can nobody get through to me?
3 REPLIES 3
Mav
Fixes: 512
Moderator's note by Mike (Mav)
Split to its own thread and title changed slightly
Forum Moderator and Customer
davidj66
Fixes: 4
Could be a crossed line at exchange.I had the same problem a couple of years ago.I actually (briefly) had another number!! If you dial 17070 it should tell you the number -if its not yours then crossed line !
Anoush
Aspiring Hero
Fixes: 139
A warm welcome to the forums @mf50bh
Have you tried running a line test here? If the troubleshooter finds a fault it'll automatically raise it to Openreach.
I hope this helps
This is my personal Community Forum account to help out around these parts while I'm at home. If I'm posting from the 1st March 2020, this means I'm off-duty with no access to internal systems.
