Re: Caller display not working
simonmoore30
I have just switched to PlusNet and since then I have no Caller ID.
It used to work before the switch and it is selected in my account details.
Each time I phone customer services I am kept waiting so long I have to ring off as I have other things to do (sorry but 30+ mins with no warning is too long to listen to very distorted hold music).
I am not sure of the etiquette for these Forums - this was posted by another customer and listed as "fixed" but I have exactly the same issue.   Should I have started a new thread?
5 REPLIES 5
sharoncj
Hi Simon,
I would start a new thread, they had mine working within an hour after posting on the forum.
Sharon.
Mav
Fixes: 510
Moderator's note:
Split to its own thread as suggested for better visibility.
Forum Moderator and Customer
abails0105
Fixes: 60
Hi @simonmoore30
Thanks for getting in contact, I am sorry to hear caller display is not working. Looking into this it appears it was unfortunately never added on to the original order. I have placed an order to add the call feature for you now and it should complete in the next 24 hours.
Apologies for the inconvenience this has caused.
 Alice Baillie
simonmoore30
Many thanks for the replies.  Caller Display/ID now appears to be working for us.
abails0105
Fixes: 60
Glad to hear it's all working for you now.
Let us know if you need any further assistance!
 Alice Baillie
