Random Noise on Line
iturner01
Hi all,
As you can probably see from the subject, I'm having issues with noise on my phone line. It's intermittent and seems to happen at random times during the day. I've checked that all my microfilters are plugged in correctly but I'm not sure what else I can do.
Does anyone else have any ideas?
2 REPLIES 2
198kHz
Fixes: 40
Re: Random Noise on Line
First thing to do is prove it in or out of your premises.
Do you have a modern NTE5A with the test socket behind the faceplate?
If so, plug an ordinary phone into the test socket and dial 17070 - choose option 2 - quiet line test.
If it's noisy, report to your telephony provider, without mentioning broadband.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
BenB
Fixes: 20
Hi iturner01,
Could you raise this to our faults team please at faults.plus.net so we can investigate this further for you.
