Quick voice line test
leader
Hi
Could the  kind  cs people run a quick voice line test on the line.
Its dead (no tone) from the nte with a corded phone.
Thanks!
Question #90955227
28 REPLIES 28
LinnPlusnet
Re: Quick voice line test
Hi Webif,
I've responded to the ticket with some own domain checks to carry out as the line test didn't return a fault.
Once the ODC's are completed please let me know if the problem still persists as this will require an engineer's visit to investigate.
leader
Thanks for the quick test! Smiley
LinnPlusnet
No problem Smiley
Just because the line test didn't return a fault found it doesn't mean that there isn't a fault on your line though. Just give me a shout once you've performed the checks outlined on the ticket and I'll get that progressed for you if required Smiley
leader
Yes will double check things before raising a fault.
I think the fttc side has also been dropping sync, more often than usual , form a quick glance of the the basic radius logs this end.
LinnPlusnet
Your line suffered various disconnections last week, however, it's been stable since Sunday -
<img src="http://community.plus.net/visualradius/generated/image14096657121636.png"/>
See how you get on with the checks and if required we'll carry out further testing from our end depending on your results Smiley
leader
After further NTE5 testing the line is still dead.
Unfortunately could a fault be rasied.
On A side note , the DLM has increased both Interleave depth  & inp ,must be over its ILQ's threasholds as well Sad
Thanks! Smiley
LinnPlusnet
Hi Webif,
I was hoping you'd come back me before I finished today Smiley
I've got that booked in for you on 05/09/2014 between 1PM and 6PM and I've also confirmed it on the ticket. Hopefully it's resolved for you!
leader
I wanted to do the full range of checks before the 5.45- 6pm deadline....  just about made it.  Smiley
The Friday ( 5th ) afternoon is great . {Added a second contact number to the ticket for the engineer}
Thanks for the OR booking and swift response!
leader
Hi
Call charges have a appeared at a rapid rate.
Please could every call starting at from 09:01:21  2nd September be flagged and stopped.
These calls have clearly not  be made from this household.
leader
I think Linn k is out of the office today?
Could another kind member of the Customer Relations Team make sure its been noted.
Thanks  Smiley
MattyC
Fixes: 46
Sorry for the lack of response Webif!
This has been duly noted and I'll update the ticket so that our faults team are aware.  Cool
leader
Much appreciated thanks!
Smiley
leader
I've now had family contacting me (via mobile) , saying somebody else has my number when they try and phone my Plusnet line.
The family / friends state the other person is convinced  its their new number!
There's the big clue on whats happened here.  Sad
This is now becoming a major inconvenience.
MattyC
Fixes: 46
Hi Webif,
I'm really sorry about this, but thanks for keeping us updated.  Undecided
Hopefully this will get fully resolved with your appointment this afternoon. I will keep an eye out to make sure that your invoice also gets fairly credited for the calls not made on your part.
