Putting down phone before hour is up
thomasjc1
Plusnet phone goes live tomorrow I'm paying the extra £4 a month for anytime calls do I still have to put the phone down and then redial if its coming up to an hour or can you be on it as long as you want
9 REPLIES 9
198kHz
Fixes: 40
Re: Putting down phone before hour is up
Yes, redial, otherwise normal will charges will apply once the hour is up!
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
thomasjc1
Ok brilliant thanks for that
198kHz
Fixes: 40
A further thought...
It says [url=http://www.plus.net/home-broadband/tariffs/][here]
Inclusive call length: Inclusive calls become chargeable after 60 minutes for UK numbers, 30 minutes for international numbers. Re-dial to avoid call charges.
Further down the page
Plusnet to Plusnet calls Free
so I assume that the hour limit doesn't apply on calls to other PN Home Phone customers.
Edit:  I assumed wrongly. See Reply #8
thomasjc1
That's great thanks for your time
198kHz
Fixes: 40
No problem - it's free on a Sunday!  Wink
A phone with a built in timer is useful.
If you start to end the call at say 50 minutes, ( to find a natural pause) it seems better than saying, 60 minutes, time to redial to save being charged.
Perhaps a going to the loo excuse ?
At least, that was what I used to do.
(Time to get a drink)
And it's less obvious you are doing the 60 minute cut-off / redial procedure.
Mav
Fixes: 512
Doesn't bother me. I simply say that I need to ring back at around the 55 minute mark. Often I ask if the other person wants to ring me back.
In the days before inclusive minutes a friend (female, I may add) had a trick of giving a a little teaser to some gossip then hanging up. More often than not the other person would ring back and she'd just apologise for getting cut off - "don't know how that happened!" Cheesy
Forum Moderator and Customer
Anotherone
Champion
Fixes: 21
Guys and Gals, the 60 minute time Limit does apply to all inclusive calls & that includes the Plusnet to Plusnet calls. See http://community.plus.net/forum/index.php/topic,108818.msg930555.html#msg930555 I assume the bug Ben had mentioned has now been fixed and the 60 minutes has been applied.
Residential and Biz are included in that, although Biz off-peak times are different to Residential.
198kHz
Fixes: 40
@ Anotherone  Thanks for the clarification.
