Product change.
- Home Phone
- Product change.
Product change.
21-08-2013 10:46 AM
Is there a best time in the month to change from Talk Anytime to Talk Evenings & Weekends? Or would I be correct in thinking that the change may be made anytime but takes effect at the next billing date?
An unjustified 50p increase in Talk Anytime has cost PN £4.50/month from the 1st October! I'll now just use mobile 'phone included minutes for all "normal" daytime calls and use an alternative for 0845 daytime calls.
If I hadn't recently paid LRS my 'phone service and broadband would be going elsewhere.
Message 1 of 4
(792 Views)
3 REPLIES 3
Re: Product change.
21-08-2013 10:50 AM
You can schedule a change at any time in the month.
Message 2 of 4
(289 Views)
Re: Product change.
21-08-2013 10:52 AM
However with respect to your LRS - does it include evenings and weekends or no calls - depends when you first took it out
If it doesn't include calls there is a charge for evenings and weekends which is presently £1.50
Message 3 of 4
(289 Views)
Re: Product change.
21-08-2013 11:50 AM
James - thanks for that.
Thanks Jim - yes, my LRS (2nd year renewal) does include evening and w/end calls.
A 12.5% multi inflation beating rise, yes only 50p/month I know, is not acceptable.
Message 4 of 4
(289 Views)
