Problems with calls from Unavailable numbers
- Home Phone
- Problems with calls from Unavailable numbers
13-12-2011 7:46 PM
I’m having ongoing problems with calls from unavailable numbers. I’m Ex Directory and registered with the TPS but still we get the calls. Is there anyway I can prevent them?
I have caller I.D. so a lot of the time I will not answer the phone but it’s getting annoying as they seem to be happening more and more.
I did look at the anonymous call feature from plusnet but the problem with that is it stops all calls including ones were the number is withheld, which would cause a problem as my GP withhold their number, so does the company my Hubby works for and a few other companies we deal with so that option is not suitable.
Is there anything else we can do or do we just have to put up with them?
Message 1 of 3
(1,490 Views)
2 REPLIES 2
Re: Problems with calls from Unavailable numbers
13-12-2011 8:06 PM
http://community.plus.net/forum/index.php/topic,99532.0.html
Have you seen this thread
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
Message 2 of 3
(472 Views)
13-12-2011 8:14 PM
No I have not, I will take a look.
Message 3 of 3
(472 Views)
- Home Phone
