Priority Fault Repair/Welfare Support
- Home Phone
- Priority Fault Repair/Welfare Support
09-04-2015 9:21 AM
I am in the process of switching my elderly mother from BT over to Plusnet (phone and broadband). She is registered blind and has a 'Home Safeguard' pendant personal alarm system that operates through the landline. For these reasons I would like to register her for the equivalent of BT's 'Priority Fault Repair' scheme (wiith which she is currently registered), should there be a line problem. I believe Plusnet call it 'Welfare Support' but I can't see how it is possible to register for this in advance, so it's on the system already, should a fault be reported?
Can anyone help please?
Message 1 of 9
(2,252 Views)
8 REPLIES 8
Re: Priority Fault Repair/Welfare Support
09-04-2015 10:46 AM
Unfortunately it isn't possible to pre-register for it so to speak.
If a phone fault were to be raised over the phone and we were made aware then we can raise it as a Emergency Welfare case.
Once she's transferred over PM me or a staff member your username and we can get a note added on top of the account.
Message 2 of 9
(1,277 Views)
09-04-2015 11:10 AM
Thanks for your reply. I will do that.
However is it then necessary to in some way 'prove' her disablement in order to get a fault raised as an 'Emergency Welfare' case?
if so, the time that would take would take would wipe out any time saved.
BT required a doctor's signature on the form to prove her qualification for the Priority Fault Repair Scheme.
Message 3 of 9
(1,277 Views)
09-04-2015 11:41 AM
As you probably know, BT have a "Free Priority Fault Repair Scheme" to expedite repairs and a "Protected Services Scheme" to ensure you don't get cut off.
Both of these require pre-registration as seems sensible for such requirements.
They may have other schemes I'm not aware of, but I investigated both of those for my very old and frail father-in-law.
Sadly PN don't seem to have anything similar and I'm sure they won't mind me saying that if such a level of protection is important then BT (not PlusNet) is the phone supplier to choose.
Message 4 of 9
(1,277 Views)
09-04-2015 11:57 AM
Message 5 of 9
(1,277 Views)
09-04-2015 12:04 PM
From previous cases I've seen on here it will be totally hit and miss as to whether it gets raised as a priority case if a fault occurs.
I'd strongly recommend cancelling the order and staying with BT as they do have a proper system in place and not the ad-hoc system used by Plusnet.
Message 6 of 9
(1,277 Views)
28-04-2015 7:29 AM
Matthew: her service has gone live today so I have sent you a PM-thank you.
Message 7 of 9
(1,277 Views)
28-04-2015 7:45 AM
Quote from: Matthew Once she's transferred over PM me or a staff member your username and we can get a note added on top of the account.
Has this been done?
Message 8 of 9
(1,277 Views)
28-04-2015 11:14 AM
Message 9 of 9
(1,277 Views)
- Home Phone
