Portal Access when?
- Home Phone
- Portal Access when?
Portal Access when?
10-04-2008 11:30 PM
How long does it take before you get access to the home phone account on the members centre?
My phone was changed over on the 8th and I received an email telling me it had been transferred and I would have access to my account "Shortly" but it still shows "Your home phone order is being processed".
Message 1 of 7
(2,223 Views)
6 REPLIES 6
Re: Portal Access when?
11-04-2008 7:47 AM
If its already been changed over, it might just need some friendly intervention by one of the PN staffers. :mand:
Doubtless one of them will be along shortly to confirm the status of the issue.
Message 2 of 7
(544 Views)
11-04-2008 10:26 AM
Hi George,
I've asked someone to have a look into this for you.
Message 3 of 7
(544 Views)
11-04-2008 10:30 AM
Thanks James, It looks like the ticket has gone back to the BOT on the 10th and been missed again.
Message 4 of 7
(544 Views)
11-04-2008 10:37 AM
Yep - Your component status is stuck, but we should be able to get it sorted by Tuesday for you.
Sorry for the delay.
Message 5 of 7
(544 Views)
11-04-2008 10:42 AM
The components I ordered ie caller ID are working James.
Message 6 of 7
(544 Views)
11-04-2008 10:50 AM
Yep, completely appreciate that.
Basically everything is active, the the actual "component" at our end is stuck from showing as an active state. I've raised a task with a developer to get this sorted, which should happen on Tuesday, but it won't cause any detrimental affects to your service, barring being able to log into the home Phone portal.
Message 7 of 7
(544 Views)
