Port landline number to VOIP provider keeping Plusnet
- Home Phone
- Re: Port landline number to VOIP provider keeping ...
14-08-2021 11:31 AM
I would like to port my landline number to my VOIP provider, so that I can accept and make calls when I am away from home.
I want to remain with Plusnet and presumably would need a new lanline landline number, although I would not need one.
Is this possible and, if so, without a lengthy break in services?
Thank you,
raj74er
Re: Port landline number to VOIP provider keeping Plusnet
14-08-2021 12:25 PM
More hassle than its worth for me.
I think things will have to change at some point in the coming years though. Once the standard ptsn telephone system is retired and everything moved to a VoIP solution, providers will have to make it easier to port numbers without ceasing internet services.
Once everyone has been forced over to SOGEA, the broadband connection won't be tied to a landline number.... So things will have to operate differently then.
14-08-2021 12:51 PM
AFAIK it's technically possible to keep an existing number by porting it to a VoIP provider whilst 'simultaneously' keeping your telephone and broadband, but with a new number allocated to it.
There is a process called 'Renumber with Number Export'; A&A ISP will do it under some circumstances, but whether PlusNet would be able or willing to is another matter.
Googling might find some further info;
14-08-2021 1:01 PM
But from what I've read, most (almost all) CPs will not do this... But I think as time goes on, they will have to.
14-08-2021 1:20 PM
Thanks to all for the replies. I know that Openreach now allow this. https://www.openreach.co.uk/cpportal/services/product-services/number-portability
Both BT and EE now appear to offer FTTC broadband without phone contract on their websites, although I not sure how subsequent porting of the number would affect the broadband. Thanks to all who have answered; I am hoping that someone will know what Plusnet will do.
14-08-2021 1:34 PM
14-08-2021 1:47 PM
14-08-2021 1:49 PM
14-08-2021 2:09 PM
@RobPN is correct, but AFAIK none of the major ISP's (including PlusNet) have systems capable of handling the process. Only A&A will do it, and only if you move to their VOIP product.
According to BT's website 'If you have a home phone number, you’ll lose it by placing an order for broadband without a landline service'. You would have to port the number to voip before placing an order, since the number must be active when ported. As has been said above, that would automatically cease the landline and broadband. So there would be a significant break in service.
14-08-2021 2:22 PM
.... I don't expect they'll be in any rush to do this, because, well... Call revenue!
17-08-2021 8:52 AM
It's probably less to do with call revenues, and more to do with demand. There would likely be a cost to implement this (changes to systems, training support staff etc...), and this isn't something that's asked for very often.
I can see the possibility of people wanting to do this more people get FTTP and the decommissioning of analog voice server, though even then I'd think the vast majority of people would just go with whatever service their ISP provide anyway.
- Home Phone
