Port Landline number when in contract
- Home Phone
- Port Landline number when in contract
18-08-2020 7:13 PM
Guys
I am looking to port my landline number when in contract with Plusnet.
I do not want to cancel my landline service with Plusnet - just continue but with a new PSTN number assigned.
Is this possible?
Re: Port Landline number when in contract
18-08-2020 9:06 PM
Hello,
In theory it is possible but it’s not a service we offer or that’s built into our systems to provide. If you port your number to another provider, this will cease both the phone line and broadband.
If you’re in contract as you say, this would also incur early termination fees as it’d trigger your account to close down automatically.
18-08-2020 9:33 PM
@Anoush I think the Op just wants a different landline number, I thought that could quite easily be arranged..... probably with a price to pay to do it.
18-08-2020 9:53 PM
While we can change the landline number for £36.63 that would cease the existing number so it can’t be ported out unless the new provider uses the same network as the rangeholder of the number and even then it may not be possible for the new provider to pick up the ceased number depending on their processes.
I believe that the OP may be referring to the ‘renumber with number export’ feature that Openreach offer but we don’t provide.
Having said that if they’re just wanting a new number and not to keep the original number then we can just renumber the line for a fee.
19-08-2020 10:09 AM
Hi
Thanks for the comments guys.
I want to keep my Plusnet service, but port the current number out to another provider (who state they can do this) and then Plusnet assign me a new number to the existing service.
Question is - how do I start the process and what do I ask plusnet for?
David
19-08-2020 10:31 AM
Unfortunately while you can port your number out to another provider, there’s nothing we can do to prevent your service from ceasing with us.
19-08-2020 2:46 PM
Thanks Anoush
Thats a big shame that you cant support "renumber with number export" - as that leaves me with the only option of leaving.
Shame - I have been with Force9 and then Plusnet for years.
David
19-08-2020 2:58 PM
I apologise for the disappointment. Unfortunately it’s largely a system limitation (as well as an offering as it’s not a service we offer).
Theres always an option of installing a new line on a second account and once that’s up and running, to port your existing number out.
19-08-2020 3:29 PM
Hi Anoush
I already have a second FTTC with another provider, and no spare pairs into the house, otherwise that was a great idea!
I guess I can port the number, effectively ceasing the service and if offered a good deal, come back to plusnet the next day.
Bit of a faff, but would work.
David
19-08-2020 5:18 PM
Don't forget about possible Early Termination charges if you're still in contract and you'll probably have to have a new account name when you come back ( although @Anoush will correct me if I'm wrong there ).
Are you wanting to port the number to voip by any chance as there might be other ways around the port ?
19-08-2020 7:05 PM
MrW.....yes, moving to SIP trunk rather than FXO,,, my ears are open!
19-08-2020 7:37 PM
Some voip providers will let you present your landline number as the outgoing cli. I know localphone ( https://www.localphone.com/ ) do. I use them at home with a gigabit voip/pstn dual phone. We also use them with the office pbx, we have incoming sip trunks from A&A but use outgoing via localphone because they are cheaper , presenting the main A & A pbx number as the cli.
19-08-2020 11:47 PM
Ah no problem, in that case if you time it well, you should be able to port your number out ceasing your service with us and sign back up when we’ve got a good deal on.
In theory that pair should be easily restarted and broadband provided back on the line. Normally takes around 7 days, or potentially longer if it’s fibre due to engineer availability.
@MisterW is correct that you’ll incur early termination fees if you’re in contract and a brand new account.
- Home Phone
