Plusnet to Plusnet
dp2010
Plusnet to Plusnet
Hi
Plusnet to plusnet calls are free says the tarriff of charges
Are they subject to charges after 60 minutes
3 REPLIES 3
adamwalker
Fixes: 217
Re: Plusnet to Plusnet
Hi dp2010,
Yes, these calls are subject to charges after 60 minutes, so don't forget to hang up and redial if needed.
 Adam Walker
Ellis
That's a good point, although as a former BT operator I can't envisage spending over an hour on the phone with a normal handset. I use a headset with Skype and would not be particularly happy with over an hour on that.
Strat
Fixes: 565
You're the wrong gender for that kind of activity Ellis. Women are designed for that, we aren't Lips_are_sealed
