Plusnet to Plusnet - anytime free calls?
- Home Phone
- Re: Plusnet to Plusnet - anytime free calls?
03-08-2013 2:40 PM
Can I just seek confirmation that calls between Plusnet home phone customers are free at any time regardless of tariff, even if one or both parties are on tariffs which are no longer available (e.g. Inclusive Evenings and Weekends)?
Message 1 of 6
(2,534 Views)
5 REPLIES 5
03-08-2013 3:14 PM
Quote All call plans
UK Mobiles 100 inclusive minutes available for £3 per month (for packages taken on or after 8th May 2013)
Plusnet to Plusnet calls Inclusive at all times
Calls to Plusnet support Free at all times
http://www.plus.net/home-broadband/tariffs/
Yes, it should definitely be free if you look at the page above
Message 2 of 6
(1,276 Views)
03-08-2013 3:45 PM
Reading -
together with -
implies that Plusnet to Plusnet calls become chargeable after 60 minutes.
Quote Plusnet to Plusnet calls Inclusive at all times
together with -
Quote Inclusive calls to UK numbers become chargeable after 60 minutes
Inclusive calls to international numbers become chargeable after 30 minutes
Calls to Plusnet Support are free for the duration of the call, regardless of length
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
Message 3 of 6
(1,276 Views)
03-08-2013 3:58 PM
Quote from: 4C implies that Plusnet to Plusnet calls become chargeable after 60 minutes.
Confirmed by Ben
Quote from: Ben Plusnet to Plusnet calls are still inclusive and theoretically limited to 60 minutes
I am not sure why "theoretically". Best to redial before 60 minutes and be safe.
Message 4 of 6
(1,276 Views)
05-08-2013 10:05 AM
Thanks all for confirming what I thought - I had taken the 60 minutes limit on a free call as read!
Message 5 of 6
(1,276 Views)
05-08-2013 11:04 AM
Plusnet-to-Plusnet calls are defined at the caller's product level, independent of the call recipient's product, etc. They should be limited to 60 minutes but I have seen some cases of calls going over 60 minutes and not picking up charging - this is currently under investigation and will be raised / fixed in due course - as such, keep them under 60 mins to avoid any surprises
Message 6 of 6
(1,276 Views)
- Home Phone
