Plusnet billing query
- Home Phone
- Plusnet billing query
07-01-2010 6:25 PM
My actual charges are... call charges £2.94 plus vat .I am on anytime call plan.
Would someone kindly take a look at my account please
Re: Plusnet billing query
07-01-2010 6:27 PM
07-01-2010 6:34 PM
08-01-2010 12:58 AM
08-01-2010 10:11 AM
08-01-2010 11:06 AM
No emails-no communication-just a very unexpected bill!!
08-01-2010 12:04 PM
I've replied to both your tickets.
The charges are as a result of you not being billed for call charges since August. The costs are reflected in your itemised bills for the correct months, but weren't charged due to a system problem.
08-01-2010 12:07 PM
This is the second part of the cleanup from a problem caused back in August, we did email the first batch of customers, but that caused more confusion and problems than it solved, so we decided not to email the second batch of customers (of which you were one).
I'm sorry if you think this was the wrong decision, and would just like to apologise to all affected for any confusion caused here.
08-01-2010 12:59 PM
After several years with plusnet, 2009 has got tbe the worst on record, we had a diabilical house move that resulted in no internet or home phone for a month either. A shocking way to treat your customers.
08-01-2010 1:18 PM
of call charges is certainly not how Plusnet, or any other business should be conducting themselfs.
I am currently awaiting a telephone call today from Ashly as to if my direct debit can be stopped for this month, at least if we had been informed PRIOR to this extra charge we could of
budgeted for it so soon after christmas.
08-01-2010 1:56 PM
The majority of customers were fixed and billed in November/early December. As I said we did email these customers but this caused more confusion. Also it's impossible to be exact with call charge amounts, as they're constantly updating up until the point you get billed (before we had a lot of customers saying you said you were going to bill me £xx.xx but you've actually billed me £xx.xx for instance).
I'd once again like to apologise, I can appreciate it's not the best time for unexpectedly higher bills.
08-01-2010 2:29 PM
08-01-2010 2:40 PM
Quote from: Mand No, you were charged the lower rate. We only updated the VAT rate on calls last night (for this reason and because some of the notifications of changes went out a little later than the 1st of December).
can you all check your VAT amount charged, mine says 17.5% when clearly it should be charged at 15% if these calls were made prior to the increase on 1st Janauary 2010.
08-01-2010 4:43 PM
I assure you it's correct though, I approved the change myself yesterday.
08-01-2010 10:49 PM
Quote from: Mand The call charge you see on your itemised bill is inclusive of VAT, without seeing the pre-VAT charge it wouldn't be possible for you to see the rate applied.
Hi Mand
are you referring to the itemised billing in My Account, if so the Hint on the far right column says "With call details you can see what time of the day you use your phone most. Click on the column headings to arrange calls by different categories. Cost is excl. VAT."
I'm really not following your point, can you please take a look at my Invoice #18858985 as I come to a different total using the calculations below.
As a breakdown, the system should in theory be adding 15% VAT to Call Charges & additional Broadband data only, all other charges should be 17.5% ie. Broadband charge & Talk 'line rental' charge. But it appears to me that 17.5% as been added to the overall subtotal while not acknowledging the fact that some of the charges relate to services (call charges and additional broadband usage) that were accumulated prior to the VAT increase.
Broken down in detail, I believe the VAT should be calculated as thus, please let me know if this is correct.
Additional Data Transfer Charge Until 01/12/2009 - £x.xx
Call charge for the period to 03/01/2010 - £x.xx
Subtotal A - £xx.xx + 15% VAT
Madasafish Max Premier Broadband charge for the period 03-01-2010 to 02-02-2010 - £x.xx
Madasafish Home Phone - Talk product charge for the period 03-01-2010 to 02-02-2010 - £x.xx
Subtotal B - £xx.xx + 17.5% VAT
Subtotal excluding VAT - £xx.xx
VAT @ 15% - £x.xx
VAT @ 17.5% - £x.xx
Total Amount Due - £xx.xx
sorry to keep banging on about this Mand, but my calculations make sense to me. If anyone would like to check their bill charges using the above calculations and let me know if their bill is correct or not I'd be really grateful, thanks
Colin
