Plusnet Hub One flashing orange light
sefm2910
No broadband/phone line for a few days. Have tried restarting hub and factory reset, checked connections (double socket), goes through green/blue cycle then back to flashing orange. Sometimes get flashing broadband symbol but then disappears. Phone line is quiet when tested. Have been no issues until now.
5 REPLIES 5
Fixes: 479
Re: Plusnet Hub One flashing orange light
@sefm2910  Welcome to the forum.
 If the phone is dead then you need to report a phone fault and get that fixed first. This will probably repair your broadband at the same time.
Fixes: 246
"No broadband/phone line for a few days"
Do you mean that you have no DIAL TONE?
If "Yes" then indeed the line will be DEAD quiet and the above applies.
If you have dial tone and you dialled 17070 option 2 and the line is fairly quiet then that might be something different.
When you dial 17070 check that the reported number is yours.
You could try changing the filter.
If it is flashing Orange, also check the account settings in the router - make sure that they reference your account.
sefm2910
Thanks, yes line is dead - I have since reported and a fault has been identified and raised for the engineers to restore the service within 1-4 days (I don't use a filter as the master socket has 2 sockets). Thanks again for taking a look.
sefm2910
Thanks, I have reported and a fault has been identified. Awaiting restoration of service - I will confirm if this also resolves the broadband issue.
Fixes: 479
Moderators Note
This topic has been moved from My Router
