Please disable my answer phone
Gavjbrown
I've been to the relevant section of my account by answer phone is green and no way to un tick it. Thanks
11 REPLIES 11
daveplus
Fixes: 10
Re: Please disable my answer phone
Have you tried https://portal.plus.net/wizard/index.html to chat or make request?
Gavjbrown
Hi Dave, live chats off at the moment but I'll have another go tomorrow. Only went live today but annoying you cant untick the answerphone from control panel, its visible but doesn't uptick.
Thank you
Fixes: 1,577
Hello there.
Can you try removing the call feature from this link?
https://www.plus.net/plustalk/index.php?page=wlr_remove_call_features
Anoush
Gavjbrown
Thanks Anoush, Thats done it Smiley
Fixes: 1,577
Awesomeness Thumbs_Up glad to hear that did the trick.
daveplus
Fixes: 10
Anoush
There doesn't seem to be any way to get to the page that you specified via the Member Centre. Why is that?
Dave
Fixes: 1,577
It's on the Home Phone Control Panel page [accessed by going to Phone Calls on the left hand side]
When you select Call Features, it's defaulted to Add call features but there's a link to Remove call features as below.
trevc
Apologies for hijacking this thread but I'd also like to disable answerphone (voicemail) on my line (or extend the time before it goes to answerphone). It is on on my line even though the call features page show it as not active. My wife is disabled and often cannot reach the phone before it goes to answerphone, which is very annoying for her.
HarryB
Fixes: 256
Apologies for any inconvenience that's been causing @trevc
It should be gone shortly, although we have to advise up to 1 working day for the order to remove the feature, to complete.
I hope this helps.
 Harry Beesley
trevc
Thanks for your help.
HarryB
Fixes: 256
No problem, let us know if there's anything else we can help with Thumbs_Up
 Harry Beesley
