Phone rings but on answering, only hear buzzing.
BionicJohn
The phone rings and the caller's ID appears.  We press the green answer button but can only hear buzzing.  The caller hears the phone ringing.
I have tried different phones but the result is the same.
We can not dial out either.
Internet is fine.
It would appear to be an external fault related to the incoming line or exchange.
Some sort of linetest would be appreciated.
Many thanks.
8 REPLIES 8
Fixes: 235
Re: Phone rings but on answering, only hear buzzing.
Hi John,
If you have a mobile phone, you can initiate an automated test yourself - see the link below.
willcutforth
Fixes: 113
Evening John, @BionicJohn
I can see this has all been raised up. Do you need me for anything else at the minute?
 Will Cutforth
BionicJohn
The OpenReach engineer is coming tomorrow. A basic test confirmed our experience - phone rings, caller ID appears, we answer but the caller continues to hear the ringing tone. Then the BT, answer phone kicks in - for which we have a notification but can't call as we have no dial tone.
BionicJohn
All sorted.
Faulty connection on line at the nearby telegraph pole.
Many thanks to the competent engineer for diagnosing and resolving quickly.
willcutforth
Fixes: 113
Awesome! Glad to hear it! If you need anything please do let me know!
 Will Cutforth
BionicJohn
You could thank David the engineer for sorting out quickly. 👍🏻
willcutforth
Fixes: 113
I will definitely feed it back for you John. Smiley
 Will Cutforth
198kHz
Fixes: 42
https://www.openreach.com/help-and-support/thank-an-engineer-form
BT technician (Retired)
