Phone rings but can't make or answer calls
DreamJackson
Hi my phone has not been working for ages
it rings and I answer but can't hear anything
I have tryed all the things you have suggested on site even went looking for
socket thingy inside, I dont have one.
I saw someone else on here had same problem
can you get it fixed please
2 REPLIES 2
jelv
Fixes: 10
Re: Phone rings but can't make or answer calls
Have you logged a fault? http://portal.plus.net/my-account/tools/phone-troubleshooter
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
MatthewWheeler
Fixes: 478
I can see you've used the troubleshooter and we've found a exchange fault.
We'll get that fixed as soon as we can.
 Matthew Wheeler
