Phone rings all the time but dead when I answer
sjw1979
Yesterday my phone rang and when I answered I just got the long tone when there is no one on the other end. I hung up and I happened again and again and again. It then happened in the middle of the night and I ended up unplugging my phone. I tried 1471 but it hasn't even registered that I've been called and so I'm wondering if it is a fault. Anybody had anything similar?? Thanks
4 REPLIES 4
PeterLoftus
Fixes: 5
Re: Phone rings all the time but dead when I answer
Doesn't happen much nowadays but is someone trying to send you a fax?
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
sjw1979
No that I know of but I suppose it's possible.
davidj66
Fixes: 4
Happened to us a few years ago, it was a damaged external phone cable causing a short. Had to have BT engineer out to replace the damaged cable section.
Anoush
Aspiring Hero
Fixes: 139
Hi there @sjw1979 I am sorry to hear you are having problems with your phone service.
I have tested your line and I have detected an Earth Contact. I've reported this through to Openreach for further investigation and the estimated response time is by the 29/03/17 23:59:59.
This is my personal Community Forum account to help out around these parts while I'm at home. If I'm posting from the 1st March 2020, this means I'm off-duty with no access to internal systems.
