Phone redirected to voicemail
ricky00130
It has been 10 days since this has happened. Couldn't dail out either. I've tried both cancelling and re-enabling voicemail on control page and it still doesn't work.
3 REPLIES 3
MattyC
Fixes: 46
Re: Phone redirected to voicemail
From testing, it seems that there is a loop condition; basically a short circuit on your line.
To rule out your equipment as the cause, we would like to see if the fault is still present with your equipment disconnected from the line.
I've created a ticket for you here, if you could confirm that the checks have been carried out, we'll take things from there.
ricky00130
Hi can you test out the phoneline now? All the cables have been unplugged.
https://www.plus.net/wizard/index.html?p=view_question&id=135165486
And this was the original question/ticket.
HarryB
Fixes: 256
Unfortunately a line test is still returning loop condition. I've raised a new ticket requesting some checks which you may or may not have already carried out, but it also has information on how to proceed with an engineer visit.
 Harry Beesley
