Phone not working
Okay
Phone not working
Hello,
My landline phone is not working, I don't know how long it's been out for.
My broadband over the same line is still working fine.
I plugged the phone into the master socket to check, but still no dial tone.
The 'report a problem' page suggests to "text..." I don't use a mobile phone.
Only way to get in touch is here for me.
Can anyone from plusnet help please?
Many thanks.
7 REPLIES 7
Gel
Champion
Fixes: 29
Okay
Re: Phone not working
I've taken the front off the master socket and plugged 2 handsets into the socket behind there and there's no dial tone. Broadband shows no problem however.
Had same problem earlier this year (or last year) and it was a connection at the pole.
What to do next?
Thanks for your help.
willcutforth
Fixes: 113
@Okay there is a disconnection on the line so I have raised this to Openreach to resolve. It should be done in the next couple of days but the Estimated Repair Time is 15th 23:59
 Will Cutforth
Okay
Thanks a lot will, much appreciated.
willcutforth
Fixes: 113
No worries Smiley I will keep an eye on it for you any way.
 Will Cutforth
Okay
The phone line is working again though no-one has been round and there have been no email updates from plusnet.
Could they have fixed it remotely without calling round? Any way to find out?
Hopefully it's not just intermittent as it means it will likely go wrong again.
willcutforth
Fixes: 113
Yeah a lot of the time it is fixed externally and they won't call. Glad it's all sorted for you though  Smiley
 Will Cutforth
