Phone not working
diddlyf
Phone not working
Broadband is working fine but landline won't send or receive calls . Market Weighton ,York
Am guessing it's Openreach, but they say to report it to Plusnet first
3 REPLIES 3
Fixes: 400
Re: Phone not working
@diddlyf
To report it work through the links in the troubleshooter here https://www.plus.net/help/phone/phone-line-troubleshooting/
diddlyf
 Thanks for that, I worked through to the " we'll test your line" point, tried twice and got message :
The result of your line check is unclear
In the meantime, problem has been fixed,  all fine again.
198kHz
Fixes: 40
@diddlyf
It's possible that there's a corroded joint somewhere on your line which doesn't affect broadband (RF) but does present a disconnection to the phone (DC).
Often a line test can temporarily clear the fault, so keep an eye on it.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
