Phone not working
- Home Phone
- Re: Phone not working
Phone not working
11-05-2021 5:33 PM - edited 11-05-2021 5:38 PM
Broadband is working fine but landline won't send or receive calls . Market Weighton ,York
Am guessing it's Openreach, but they say to report it to Plusnet first
11-05-2021 5:50 PM
To report it work through the links in the troubleshooter here https://www.plus.net/help/phone/phone-line-troubleshooting/
11-05-2021 6:18 PM
Thanks for that, I worked through to the " we'll test your line" point, tried twice and got message :
The result of your line check is unclear
In the meantime, problem has been fixed, all fine again.
12-05-2021 3:17 AM
It's possible that there's a corroded joint somewhere on your line which doesn't affect broadband (RF) but does present a disconnection to the phone (DC).
Often a line test can temporarily clear the fault, so keep an eye on it.
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
