Phone not ringing
- Home Phone
- Phone not ringing
Phone not ringing
19-09-2012 2:25 PM
I have had 2 missed calls today that I know of when my phone didn't ring, one a spam call from BT I think on 08003289393 and another from a recruitment agency I applied to.
I did the ring back test and it failed to ring with everything connected as normal. Then tried with just my phone in the master socket and no filter, that worked. Then with filter and my router and it worked then.
Possible sign of a dying filter or phone?
FTTP 500 regrade from Tues 28th November
Message 1 of 3
(1,154 Views)
2 REPLIES 2
Re: Phone not ringing
19-09-2012 2:35 PM
Quite possibly either; or just a knock or bump that pulled the cable out of alignment? I wouldn't worry too much unless it re-occurs then consider replacing items, cheapest first, until the problem goes away.
Message 2 of 3
(474 Views)
19-09-2012 8:50 PM
Possibly only one missed call, as 08003289393 is a generic BT CLI presented when the ringback test facility is used.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
Message 3 of 3
(474 Views)
