Phone line not working
- Home Phone
- Phone line not working
04-01-2014 5:31 PM
Can anyone help?
My Plusnet phoneline is completely dead. The internet connection is ok (although a bit intermittent) but the phone line is just dead. I have checked my phones and have no battery issue and I have tried a different handset. Still no joy. Can it be something up with the Plusnet phone line or is there something else my end I should be looking at?
Also - annoyingly, I have asked Plusnet to activate call divert at-least three times and it keeps not getting done. I use my landline for work calls and am concerned I am missing calls.
Message 1 of 9
(1,669 Views)
8 REPLIES 8
Re: Phone line not working
06-01-2014 10:20 AM
Hi there, I've just tested the line and diagnostics are showing a potential "loop fault" this can be caused by an issue with your equipment so we'd like to be able to run another such line test with everything disconnected from your line. Let us know if you'd be able to line things up for us to be able to do that today.
Message 2 of 9
(574 Views)
06-01-2014 12:13 PM
Hi Adam
Thanks for the speedy response. I am not at home right now but will be back at 2:30 pm and will unplug. Do I need to unplug the internet too? If I unplug all I wont be able to email to let you know I am doing it! Also - I realize that my internet connection is slower than normal and v intermittent.
Jessica
Jessica
Message 3 of 9
(574 Views)
06-01-2014 12:36 PM
Quote I wont be able to email to let you know I am doing it!
In that case if you can perhaps leave everything unplugged for 15 minutes at 2.30 that leaves a window for me to do the test in, does that sound OK?
Adam
Message 4 of 9
(574 Views)
06-01-2014 12:50 PM
That is great. Thank you Adam. I will unplug everything at 2:30. Thanks v much for your speedy replies.
Message 5 of 9
(574 Views)
06-01-2014 2:38 PM
Thanks, the tests in that state aren't indicating any problems, so this could mean that one of your devices that's usually connected to the line is causing the loop fault.
Have you tried swapping out the filter that the router is usually connected to?
Message 6 of 9
(574 Views)
06-01-2014 2:56 PM
Hi Adam - thanks so much for your speedy response. I am very impressed (as always!) with Plusnet support and costumer service. When I plugged it all back in, it all works! I am not sure what you mean by "this could mean that one of your devices that's usually connected to the line is causing the loop fault." Is the filter the phone jack thing? Should I buy a new one do you think?
Also - on a different topic, I have been asking for call divert to be activated so I can divert to my mobile. Can you tell me if this has been done now?
Thank you
Thank you
Message 7 of 9
(574 Views)
06-01-2014 3:33 PM
Thanks for letting me know.
Yes and I'd no need if it's working now but it might be an idea to buy one as a spare if you don't already have one just in case that happens again.
Sorry I forgot to mention that in my previous reply, it should be already active at the moment.I'm just wondering whether you're setting that up to divert all calls or just when engaged or unanswered?
Quote Is the filter the phone jack thing? Should I buy a new one do you think?
Quote I have been asking for call divert to be activated so I can divert to my mobile. Can you tell me if this has been done now?
Message 8 of 9
(574 Views)
06-01-2014 3:47 PM
I want to set it up for all calls. It is for when I am out. Thanks v much again. Super impressed with Plusnet. Will by a new phone jack thingy asap for future ref.
Jessoca
Jessoca
Message 9 of 9
(574 Views)
