Phone line dead after pole upgrade
- Home Phone
- Re: Phone line dead after pole upgrade
on 01-03-2018 4:40 AM - last edited on 01-03-2018 5:23 AM by dvorak
Plusnet username: [Removed]
Yesterday morning some people turned up and installed two new poles on my street. This required the phone line to be taken down while this was done. But when they left our phone has no dial tone and is dead. Worst of all (obviously) there is no 'broadband' light on my openreach modem and so no internet.
I am currently on my works broadband (at this hour!) As I have no mobile data this no other means of getting here.
I wasn't sure if I would have to come here or to openreach but as I have phone/'net/you view here I thought this would be the place to start.
Moderator's note by Adie (Dvorak) removed username as it's a public forum
01-03-2018 9:59 AM - edited 01-03-2018 10:00 AM
Hi Pete,
Sadly though your issue has been caused by Openreach or their sub-contractor engineers, they offer no means by which users impacted by their failures can obtain direct priority redress.
You need to contact your retail supplier - in this case Plusnet - and report a phone line fault. You can try the on-line fault tester, however that has a 50% chance of reporting a failure in the test process, but 50% of such failures result in a successful report to Openreach. You will need to look at your PN tickets (see link) to see if a fault report was actually raised. Other than that its chat or a phone call.
You can run the fault checker from any where?
01-03-2018 3:03 PM
Hello
I found the phone line tester a little while after I posted and it did report a fault. I received a phone call from a Openreach tech guy who asked a few questions before saying he would come out and do a few tests but as to what could be done what with the weather, well, that would be anyone's guess.
As luck would have it there was someone with a hydraulic platform locally which got him up to the pole. So everything is now fixed
01-03-2018 9:50 PM
Buy a lottery ticket!
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
02-03-2018 12:39 PM - edited 02-03-2018 12:41 PM
- Home Phone
