Phone dead as of 1:00pm this afternoon
- Home Phone
- Phone dead as of 1:00pm this afternoon
13-08-2014 5:21 PM
Just thought I'd add my voice to everyone else's!
I've logged a call with support although I imaging they are now swamped!
Message 1 of 5
(861 Views)
4 REPLIES 4
Re: Phone dead as of 1:00pm this afternoon
13-08-2014 6:03 PM
Hi skuzzbag,
I just ran a test of your line and nothing was picked up as looking like a fault, have you checked that the phone is working (if battery operated) and tried plugging it into the master socket with everything else unplugged?
Normally if no dial tone is found, we would see the fault flagged the second we ran the testing and nothing has turned up in this instance
Message 2 of 5
(434 Views)
13-08-2014 6:23 PM
Hi Skuzzbag,
Welcome to the forums. Given the test run by Adam, is there any possibility that another phones in an extension has got knocked off hook? No dial tone and no fault detected is unusual. When did you notice there was no dial tone? Could it possibly be soon after receiving an incoming call? Sometimes in bound calls do not clear down properly leaving the calling party connected to your phone line.
Is the BB working OK?
Kevin
Kevin
Message 3 of 5
(434 Views)
13-08-2014 9:38 PM
Hi, I got home and took everything out of the sockets, attached a filter and the phone and checked and the line was OK. Attached the modem and once I rebooted it everything was working again.
Sorry maybe this was a false alarm!
Thanks for your help though
Message 4 of 5
(434 Views)
14-08-2014 6:43 AM
Last month I suffered a loss of dial tone for two long periods in the space on an hour one evening. I presume that was somebody messing around in the telephone exchange. Did you try again before you took everything out of the phone sockets? If the dial tone was still absent but disconnecting everything cured the problem then it was definitely something in your house that caused the problem.
Message 5 of 5
(434 Views)
- Home Phone
