Phone charge no mobile signal
K8
I been told i have to pay £36 to change my landline number.... i have to change as im being harrassed still by an ex who assulted me 9months ago. I changed my mobile to plusnet but there no mobile signal. Iv had to unplug my landline as it effecting me mentally. When i was explaining this i got cut off.
11 REPLIES 11
harrow
Re: Phone charge no mobile signal
On bt they have a free service called BT Call Protect.
BT Call Protect – a clever bit of technology that helps prevent nuisance calls. It’s easy to switch on and free for BT customers.
Once on, we’ll monitor for known nuisance callers and automatically divert them for you. If there’s a particular number you don’t want to hear from again, you can add them to your personal blacklist to send future calls to your junk voicemail.
Plus, if there’s a category of numbers you don’t want to hear from – like international, withheld or unrecognised numbers – you can send them straight to junk voicemail.
I don't know if PN does it but I think they should if they are owned by bt.
PN, where did it all go wrong ?
Fixes: 395
Plusnet do provide the Call Protect service and it is free https://www.plus.net/help/phone/stop-nuisance-calls/
harrow
Well my Add Call Features panel must be different from yours,
Anonymous Call £4.00 per month,
If a caller withholds their number, they won't be able to call you.
harrow
That seems to be the only applicable option.
jelv
Fixes: 10
@K8
Looking at the information MisterW linked, do you have a crime reference number? If so give that to Plusnet and the fee to change your number should be waived. However...
There is always a chance your ex will discover your new number so I'd suggest using Call Protect and adding the callers number(s) to your personal blacklist might be the better way.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 395
Attached is screenshot of my Phone control panel , Call Features. As you can see Call Protect is there as an option at a cost of £0.00
harrow
No sorry your picture says it's £4 a month,
the same as mine
Fixes: 395
Anonymous Call IS £4.00/month BUT Plusnet Call Protect is clearly shown as £0.00/month
harrow
Mine is a
Business Phone Control Panel
it is not an option on mine,
there is only Anonymous Call reject @£4 per month.
Fixes: 395
That might explain the difference!. I assume the OP is a Domestic rather than a Business customer and therefore should have the Call Protect option.
Fixes: 1,600
I'm sorry to hear of your situation @K8
I'd like to call you to discuss this further, is there a best contact number and time?
Please send me a private message.
Plusnet Call Protect is only available on residential packages.
