Phone calls past midnight now no phone line
RoyM74
Hi. I know this might be difficult to resolve but our house phone rang 3 times around 0.30 with 'unknown' displayed number
My wife managed to catch the 3rd ring nothing on the end of line except electronic buzzing background noise. In the next hour we couldn't ring out or indeed ring in from our mobile phones
Any suggestions?
Current time is 01:23
Thank you
6 REPLIES 6
Fixes: 160
Re: Phone calls past midnight now no phone line
Hi Roy,
A warm welcome to the forums.  This is disconcerting.  It sounds as though the caller has held the line "off hook" in effect blocking the line - a technique used by scammers to "demonstrate / suggest" that they have the ability to cut your phone line off.
What signal do your mobile phones hear - engaged or unavailable?
I take it you have no dial tone?
Is the internet working OK?
Try running the phone line trouble shooter (phone faults link below).
RoyM74
Hi many thanks
Our mobiles tell us we are on a call
Internet seems fine and line is unlocked this morning. Weird
Fixes: 160
That call left the line on hook which lays somewhere between odd and suspicious. Eventually the line self cleared down the silent call as you’ve seen this morning.
Keep an eye on your phone bill less this was some odd ball phone scam.
198kHz
Fixes: 41
To clarify - was it actually 'buzzing', similar to mains hum but higher pitched, or a series of fast-changing audio tones ie a data stream?
If the latter, then possibly a faulty or wrongly programmed fax machine or automatic telemetry device.
0030 seems an odd time to attempt a scam on a UK number.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
RoyM74
It was a continuous buzz similar to a volume being set too high. I'll monitor it and report back any reoccurrence
Thanks all for helping so far
198kHz
Fixes: 41
Thanks for clarification. Hopefully it was a one off.
