Phone calls past midnight now no phone line
- Home Phone
- Phone calls past midnight now no phone line
23-11-2017 1:23 AM
My wife managed to catch the 3rd ring nothing on the end of line except electronic buzzing background noise. In the next hour we couldn't ring out or indeed ring in from our mobile phones
Any suggestions?
Current time is 01:23
Thank you
Re: Phone calls past midnight now no phone line
23-11-2017 1:56 AM - edited 23-11-2017 1:57 AM
Hi Roy,
A warm welcome to the forums. This is disconcerting. It sounds as though the caller has held the line "off hook" in effect blocking the line - a technique used by scammers to "demonstrate / suggest" that they have the ability to cut your phone line off.
What signal do your mobile phones hear - engaged or unavailable?
I take it you have no dial tone?
Is the internet working OK?
Try running the phone line trouble shooter (phone faults link below).
23-11-2017 7:00 AM
Our mobiles tell us we are on a call
Internet seems fine and line is unlocked this morning. Weird
23-11-2017 8:31 AM
Keep an eye on your phone bill less this was some odd ball phone scam.
23-11-2017 11:15 AM
To clarify - was it actually 'buzzing', similar to mains hum but higher pitched, or a series of fast-changing audio tones ie a data stream?
If the latter, then possibly a faulty or wrongly programmed fax machine or automatic telemetry device.
0030 seems an odd time to attempt a scam on a UK number.
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
23-11-2017 1:56 PM
Thanks all for helping so far
23-11-2017 1:59 PM
Thanks for clarification. Hopefully it was a one off.
- Home Phone
