Phone beeping during calls - help! :)
- Home Phone
- Re: Phone beeping during calls - help! :)
02-08-2018 5:38 PM
Hi all, hope someone can help me. Every time I make landline calls, every 10 minutes or so I get a series of long beeps - usually three - at which time neither I nor the other caller can hear each other. I don't have call waiting, and it isn't an answer machine alert. Any ideas? It's driving me slightly insane.
Thanks, and hope all are well.
02-08-2018 8:40 PM
Is this a DECT cordless phone?
Could it be the battery low signal? Eventually the rechargeable batteries wear out giving you only a short period of talk time.
02-08-2018 8:53 PM
Thank you Townman, and thanks for responding
It is a DECT phone (5-7 yr old BT jobbie) and it did cross my mind that it might be a battery issue. But the phone I invariably use is always topped up. Could it be that even with a 'full' battery indicator there's still insufficient charge? Maybe new batteries could be at least one way of knowing if that's the problem, or not. Will give it a go - can always do with batteries.
Thanks again.
02-08-2018 11:41 PM
Remember to use rechargeable replacement batteries and not standard alkaline
Batteries have a limited life and old batteries can fall off a cliff.and quickly go from full charge to no charge
03-08-2018 10:11 AM
Hi @Kranglemeister, no worries let us know if that's helped or if you're still having a problem.
03-08-2018 7:34 PM
Thank you, will do
03-08-2018 7:35 PM
Have ordered some now - fingers crossed. Chers
- Home Phone
