Phone Wall SOCKET
jockwav
Phone Wall SOCKET
This is something i dont think i ever got an explanation of why.
When i got my new phone line fitted last year & they fitted the master socket i got the old style with a plugin filter.
Why i never got an NTE5 ADSL filtered faceplate fitted i will never know as i never seemed to get a reasonable explanation as to why not.
So if anyone could shed somne light on this for me i would be very grateful. Huh
https://www.flickr.com/photos/james_bingham/
14 REPLIES 14
jelv
Fixes: 10
Re: Phone Wall SOCKET
"old style"
Was it one with the removable lower half and a test socket inside?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
jockwav
yep it has 2 screws to remove the bottom half,but whats that got to do with the built in filter one NTE5. Huh
jelv
Fixes: 10
Because that's the one they are required to fit, there's no obligation for them to fit the filtered one (excepting FTTC where they also provide the modem).
jockwav
God these old filters are out of the ark,i even offered the bt engineer payment if he would fit one,but he was a miserable sod if i remember.
So what to do here am i allowed to get someone to fit one of these NTE5 or whats the score. Roll_eyes
jelv
Fixes: 10
You can do whatever you want from the test socket inwards. The filtered sockets replace the removable lower half and plug in to the test socket so you are perfectly OK to do so yourself.
jockwav
Thought as much cheers.
jockwav
So i take it there is no wiring involved in changing the front plate for one of these, BT Telephone ADSL Broadband Faceplate Filter Adaptor
jelv
Fixes: 10
If you have no extensions, no wiring needed. If you have extensions you connect them to the back of the filtered face plate.
Anotherone
Champion
Fixes: 21
@jockwav
I'm surprised you didn't get an ADSL SSFP, you couldn't have approached the guy in the right way or he was a right miserable git. Mind you, I trust you realise that your modem/router has to be plugged in at the Master socket if you have one of those, rather than at an extension socket.
jockwav
Quote from: jelv
No extentions to worry about. Grin
jockwav
Quote from: Anotherone
@jockwav
He was a miserable git,i even offered him coffee & biccys,no extention  sockets just the master. Smiley
Anotherone
Champion
Fixes: 21
Next time you see an OR eng anywhere, go and say hello. If they seem approachable, just say you are on the scrounge for a SSFP  Wink You never know your luck.
jockwav
Got a new FP ordered now. Smiley
jockwav
Fitted my new filtered faceplate in 5 minutes,excellent. Grin
