Phone Line noise
- Home Phone
- Phone Line noise
Phone Line noise
11-05-2013 8:46 PM
Hi guys tried using phone past couple of day and all I'm hearing all over the phone line is like a static noise
Started happening about two day's ago
Nothing has been moved or changed at my end !!
Message 1 of 3
(1,177 Views)
2 REPLIES 2
Re: Phone Line noise
11-05-2013 9:48 PM
Try a phone (preferably a corded one) in the test socket behind the master socket if available.
If the noise is still there report it to your phone service provider.
Message 2 of 3
(382 Views)
13-05-2013 5:09 PM
I can see that we're your phone provider, I've just been running a line test specifically for noise issues and the results didn't indicate a problem.
I'd advise giving support a call (0800 432 0200) or heading straight to http://faults.plus.net if that's still an issue.
Adam
Adam
Message 3 of 3
(382 Views)
