Permanently withold number
danielmeekings
I believe I requested that my number be witheld when signing up to Plusnet, but this doesn't appear to have been done - speaking to a customer service rep via online chat I was told that it wasn't possible to permanently withold my number, could only do it by dialling 141 or whatever before each call, however having read a message on the forum it appears that this is incorrect.
Is it possible to permanently withold my number please?
Many Thanks
Daniel
16 REPLIES 16
MattyC
Fixes: 46
Re: Permanently withold number
Hi Daniel,
Generally we don't offer number withheld as a feature, however I cannot see any reason why we can't just offer this to you at a wholesale level. I'll get an order placed for you, and I'd recommend checking your line in 24 hours.
Matty
danielmeekings
That's great - thanks very much.
MattyC
Fixes: 46
Is it working for you now?
Matty
danielmeekings
Haven't been able to check as yet - will do so this evening when I'm back from work and let you know.
Daniel
danielmeekings
That has sorted it - many thanks.
Powell40
I am currently with BT but having had poor speed I fed up and considering changing currently I have this on my account is it possible to permently add with hold number to my account with plusnet if not I will have to look at another supplier.
HarryB
Fixes: 256
Hi @Powell40,
Although this isn't really a feature we actively offer (You can't add it via the member centre as you can with other call features) if you do sign up with and drop us a message here on the forums we can arrange to get this sorted for you.
I hope this helps.
 Harry Beesley
bistellio
Hello, please can you also do this for me, I thought my number would transfer over and still be withheld. Many thanks
deank
Fixes: 14
Hi there.
We can do this for you. I have raised a ticket on your account regarding this, if you can please respond to that I can get this actioned for you. You can view the ticket at https://www.plus.net/wizard/?p=view_question&id=178535085
bistellio
Hello I have responded to the ticket, please could you apply the change. Many thanks for your help.
Fixes: 1,600
Thanks @bistellio, I've done that for you now which should be ready within a few hours.
bistellio
Thanks!
Fixes: 1,600
No problems. Let us know if you have any further queries.
ostias
Hi, I would like my number permanently witheld. How do I go about getting this done?
Regards
david
