Permanently withhold number - Can't get through to call centre
SnappyW
I would like to have my number witheld when I make calls, but retain the option to send my number with 1470 or similar, but I am having a little difficulty getting through to you to so that you can help me with this. Is it possible that you can pass this on to the proper team to enable this feature for me please.
Thanks,
Harry
4 REPLIES 4
Gel
Aspiring Champion
Fixes: 27
Re: Permanently withhold number - Can't get through to call centre
Fixes: 1,576
Hi Harry.
I've placed an order to add that now.
It should be working within an hour or so.
I hope this helps.
SnappyW
Thanks Gandalf,
Cheers,
Harry
Fixes: 1,576
No problems Harry.
