Permanent Call barring on Plusnet
- Home Phone
- Re: Permanent Call barring on Plusnet
08-01-2014 10:52 AM
Decided to provide broadband so long as the monthly bill will be 100% predictable. Will add it to the rent.
This avoids the need for e.g. foreign students to have a delay getting connected due to credit check or unwanted long contract issues etc.
Having decided, I find that Virgin Media who I know offer 'Broadband Only' with no phone line does not serve the address - not a cabled building.
I have been phoning the Plusnet sales line for an answer to see if Plusnet can offer a 'virtual no phone line' broadband service where any chargeable outgoing calls are guaranteed to be blocked (0800 and 999/112 would be acceptable). But no-one picks up at Plusnet! So I hope someone here can answer.
Is there a Help Page on the Plusnet explaining exactly how this outgoing block would work?
What is the current status - can Plusnet guarantee that unless the account holder explicitly changes things, there's a way to block chargeable outbound calls?
08-01-2014 4:27 PM
P.S. It's often better to start a new thread if there hasn't been a recent discussion on the topic - saves any confusion with past discussion
08-01-2014 4:30 PM
08-01-2014 4:46 PM
But I have now discovered that in any case there appears to be no way to prevent Reverse Charge calls and these can cost a fortune.
All in all it's entirely within the power of the telcos to offer what I require to people whose main use of a phone line is Internet and especially to landlords.
I am now going the way of offering a Three 3g/4g WiFi hotspot instead - the ISPs don't want my money!
08-01-2014 5:07 PM
Edit: I'm sorry if this 'doesn't inspire confidence' but the reason we also state that call barring might not stay on is because billing controls call barring and there are scenarios where we expect billing to place a 'remove call barring' order. This is entirely by design.
08-01-2014 5:24 PM
Hence I have assumed the same will be true of Plusnet unless & can see a Ts&Cs page on Plusnet's site to the contrary.
08-01-2014 5:25 PM
Why not just charge your tenants the charges for the phone and broadband service and add it into your tenancy agreement?
08-01-2014 5:41 PM
- The day the tenant arrives (possibly from abroad) the water, power and WiFi is working
- Because of the variable costs involved, the tenant will take over water and power contracts per tenancy agreement. Meters will have been read on arrival there's a tried & tested procedure for this.
- I wanted absolutely fixed cost broadband with no possibility of unknown phone charges. Were the property on Virgin cable for example, Virgin's 'Broadband Only no phone' line would have done this perfectly.
- When the tenant moves out, meters are read again, their contract to pay arrears on power & water is with the companies and not me.
- The day the tenant moves out, the WiFi stays working so its immediately available to the next tenant. No complex procedures.
I've been on other forums and many landlords are looking for this broadband solution and not getting clear answers!
Those with Virgin cable only are looking a bit smug though!
08-01-2014 7:06 PM
AAISP might have a solution for you - you can get a broadband only line with your broadband with them for £10 a month line rental, and it can't be used for calls. See http://www.aa.net.uk/broadband-home1-info.html#more for more info.
09-01-2014 9:06 AM
If you can't plug in a phone, then you can't make calls or receive reverse-charge calls. (You can't receive any calls at all, which may not be what you want.)
09-01-2014 5:45 PM
Any over-usage, though improbable, is billable. AA does not have flat rate all you can eat. Interesting suggestion, I suppose no worse than a £20 unlimited data + landline rental deal.
Re locked cupdboard etc - this is a new refurb and I don't want to mess around with anything. The tenant may later want to take on a contract, fine by me but I don't want to have tampered with the box.
10-01-2014 9:59 AM
Edit: If anyone did fit such a box (I take it netgran is not the only landlady or landlord with this problem), it would be a courtesy to mount it such that the keyholder could remove it quickly, so that BT could work on the socket if they had to without it being in the technician's way.
10-01-2014 12:52 PM
Also I installed Plusnet for a relative a while back and found out how easy it was to DIY it, very pleased.
BUT regarding this new BTL project, an Email with Plusnet Sales is now telling me that In/out call barring would not be an option with Plusnet. What a pity!
I pointed out to Sales that Openreach offers both in and out barring as an option to the resellers so I wonder if Sales will be able to improve the offer?
On top of all that, if my tenant may want to upgrade once they've settled in. I assume that an "transfer of responsibility" would then be possibility so they can take over the Plusnet contract ad add phone etc.
Well, there business going begging here if Plusnet can adapt to the landlord market!
10-01-2014 2:55 PM
10-01-2014 4:16 PM
- Home Phone
