PN's default voicemail setting
- Home Phone
- PN's default voicemail setting
02-11-2013 10:56 PM
With my previous suppliers the default setting for "free" voicemail was off, which in my opinion is more sensible.
After some digging around I've learned it takes up to three working days to get it changed, what the .... !
Re: PN's default voicemail setting
03-11-2013 2:28 AM
[quote=Jess virtual help assistant]
Whether you're away from home or on another call, Voicemail acts like a built in answerphone to make sure you don't miss a call. Standard Voicemail is included with all our phone packages, but it's not switched on as standard. You can add or remove it at the Phone control panel.
So it should be off by default. Was starting with it on an option on sign-up?
03-11-2013 3:26 PM
04-11-2013 9:00 AM
04-11-2013 1:33 PM
04-11-2013 1:47 PM
04-11-2013 10:22 PM
04-11-2013 10:53 PM
Quote from: Ben It's an option presented during signup, I think it defaults to 'on'.
Not so sure now what the default setting is after reading [color=red]2.1. which can be found in the attachment below. [/color]
05-11-2013 9:24 AM
05-11-2013 1:34 PM
- Home Phone
