One leg DIS fault?
- Home Phone
- Re: One leg DIS fault?
One leg DIS fault?
14-07-2017 10:38 PM
I seem to have a common problem - no dial tone on the phone but BB works at about 60% speed. I know - I should phone support (using what phone?) but it always takes ages to get through and I'm reluctant to use a friend's phone for that reason. Is there any way to report the fault online?
14-07-2017 10:58 PM - edited 14-07-2017 10:59 PM
Hi there
You should be able to test your phone line here.
At the moment, I don't believe that the result at the end of the test is very informative. If the troubleshooter detects an external fault it'll report it to Openreach automatically and it will raise a ticket here for our faults team to follow up on.
I hope this helps
Anoush
15-07-2017 8:14 AM
Already tried this several times and get the message
The result of your line check is unclear.
with the advice to phone support for more information.
So I'm still stuck!
I do however know that there has been some roadworks in the neighbourhood and it could well be that this has caused the fault.
15-07-2017 11:24 AM
Since the above, I've been able to chat online with a Plusnet agent as a result of which a fault notification has been raised with Openreach. So hopefully the fault will be rectified soon.
17-07-2017 9:54 AM
