On Anytime, but charged for local calls
Mad_Moggies
Start of billing month was 25th and there are two calls to local numbers on 25th showing as charged. All was OK up to 24th. Account is showing correctly as Anytime, so we shouldn't be getting charged for calls - one of 10 mins and the other of 2 mins, so definitely not over the time limit for free calls. We've made calls since then but they're not showing yet. Have been on anytime since Dec 25th 2009.
I've raised a ticket but it's showing as a 20 hour response time so thought if I post here it might be sorted out more quickly!
Looks a bit odd anyway, with earlier dates shown than those the summary says it's for, and no times given for any of the calls.
UK Landline call summary - 25/01/2010 to 24/02/2010
  Date of call Number called Time of call Duration   Cost
25/01/2010 020XXXXXXXX 00:00:00 00:10:24   £0.64
25/01/2010 020XXXXXXXX 00:00:00 00:02:12   £0.21
24/01/2010 016XXXXXXXX 00:00:00 00:17:30   £0.00
23/01/2010 011XXXXXXXX 00:00:00 00:05:36   £0.00
22/01/2010 019XXXXXXXX 00:00:00 00:06:36   £0.00
22/01/2010 019XXXXXXXX 00:00:00 00:01:00   £0.00
  TOTAL:   £0.85
Plusnet user since November 2003
Full Fibre since September 2023
Mac OS14 and Firefox user with latest versions of both
9 REPLIES 9
mal0z
Re: On Anytime, but charged for local calls
There is indeed a problem, but it is know about by PN and being addressed.
Note the timestamp lists all the calls at midnight
http://portal.plus.net/supportpages.html?a=2&support_action=messages&ispservice_id=homephone
Mad_Moggies
Still doesn't explain why I've been charged for local calls to landlines when I'm on Anytime.
Mand
I suspect this is due to the midnight time stamp, but I'll make sure it's looked at tomorrow and confirm (call processing is currently turned *off* so you won't get any more calls appearing until the issue is fixed).
Mad_Moggies
Thanks Mand, but why would a midnight timestamp cause non-chargeable Anytime calls to attract a charge and then only those after the billing date? Huh
Mand
The problem only affects calls between the 19th and the 26th, I'm just checking a few things with the devs then I'll report back.
Mad_Moggies
Thanks Mand.
My calls from 19th to 24th haven't been charged but those on 25th (first day of new billing month) have been charged. Also, the date stamp is only 00.00.00 from 22nd Jan, which are just the calls showing when I look at the UK Landline Summary on my current billing period (see first posting above).
Below is what I see when I look at the general Recent Calls page:
  020XXXXXXXX    25/01/2010 00:00:00    00:02:12    £0.21
020XXXXXXXX 25/01/2010 00:00:00 00:10:24 £0.64
016XXXXXXXX 24/01/2010 00:00:00 00:17:30 £0.00
011XXXXXXXX 23/01/2010 00:00:00 00:05:36 £0.00
019XXXXXXXX 22/01/2010 00:00:00 00:06:36 £0.00
019XXXXXXXX 22/01/2010 00:00:00 00:01:00 £0.00
020XXXXXXXX 21/01/2010 16:17:08 00:04:24 £0.00
020XXXXXXXX 21/01/2010 16:15:05 00:01:00 £0.00
020XXXXXXXX 21/01/2010 16:13:05 00:01:00 £0.00
020XXXXXXXX 21/01/2010 16:11:26 00:01:00 £0.00
Mad_Moggies
Just had a reply to my ticket raised on Saturday, and have been told I've had the 85p credited back to my account, though I can't see it anywhere as yet! Will let them know you are looking into it anyway, Mand.
Mand
This should be sorted now.
Mad_Moggies
All looks fine now, Mand.
Thanks again! Smiley
