Old calls in current bill
- Home Phone
- Re: Old calls in current bill
20-07-2008 10:42 AM
When viewing "Itemised Bill" with the bill date clearly showing for instance 08/07/2008 to 07/08/2008.
Then "View details"
As well as the current details, there are calls listed which are dated well before the displayed billing period.
I don't understand.
Then "View details"
I don't understand.
Message 1 of 7
(2,043 Views)
6 REPLIES 6
20-07-2008 11:17 AM
I think thats as a result of the current hash up with the comfirmations, keep an eye on it, if it takes you over the free limit complain vigorously.
If it is calls you have to pay for left over from last month, unfortunately they will now have to be paid.
Not very satisfactory but
Message 2 of 7
(491 Views)
20-07-2008 11:45 AM
Thanks PP
Are you saying that these calls will be ones that were unconfirmed at the end of the previous billing period, so are subsequently added to this one?
I'll trawl through the previous bill to make sure I'm not being charged twice.
I'm new to the PN phone service and I'm finding the whole billing system a bit hard to get my head round. Doesn't help that I started right in the middle of their billing problems I s'pose. Also I'm battling with the painfully slow task of switching between some of the PN pages. (as I mentioned in another thread)
Andy
Andy
Message 3 of 7
(491 Views)
20-07-2008 12:14 PM
at the bottom of the details page is a link to download the details as a CSV file for using in a speadsheet, this will make life a bit easier.
I know I am on 6m speed, but dont have any trouble between pages
Message 4 of 7
(491 Views)
20-07-2008 12:31 PM
Cheers for that.
This speed thing is odd indeed. It seems to only be the PN site. Sometimes the little blue loading stripe doesn't even appear in the (status bar?) at the bottom untill I've clicked, clicked or double clicked, or double double clicked. Sometimes 3 or 4 rapid clicks jolts it into action.
Message 5 of 7
(491 Views)
20-07-2008 2:36 PM
Quote from: dosch Thanks PP
That's likely to be what's happened. It will have been compounded by the recent problems as described here.
Message 6 of 7
(491 Views)
20-07-2008 6:28 PM
To you both:
Thanks for taking the time to explain.
A
A
Message 7 of 7
(491 Views)
- Home Phone
