Old BT wire colours
mikehale77
Old BT wire colours
My extensions were installed by BT using the following convention:-
2 solid blue
3 solid green
5 solid orange
They were taken off upstream of the master socket at a line block .
Can anyone tell me the likely installation year(s)?
Mike
1 REPLY 1
Nick_Russell
Re: Old BT wire colours
This site indicates "pre 1980" -
On older installations (pre-1980) cream or grey cables were used. They contained conductors coloured blue to pin 2, orange to pin 5, brown to pin 3 and green to pin 4 (if used), on some conversions green was used for pin 3 and brown for pin 4.
Additional Bells are wired between pin 3 (orange/white) and pin 5 (white/blue).
http://www.telephonesuk.co.uk/wiring_info.htm
