Number with held but need 1470
Harman110
My number is withheld (and I want that to remain) but I can see from previous posts that if I want to selectively show my number using the 1470 feature, this has to be enabled. Please can you enable this on my line. I cant currently call my sister 😞
Thanks and regards
Ann Harman
3 REPLIES 3
Fixes: 1,603
Re: Number with held but need 1470
Thanks for your post @Harman110
I'm sorting this for you now and you should be able to un-withhold your number using 1470 after an hour.
Let me know if there's anything else you'd need help with.
Fixes: 1,603
Hi @Harman110 as an update on this, the order I placed to change the configuration in the call feature hasn't completed yet, but I'm monitoring this and I'll let you know once it has gone through.
Fixes: 1,603
It's just me again. I can confirm the order has completed so you should now be able to un-withhold your number at will
