Number of rings before Call Divert no Answer
monolog99
I have Call Divert on No answer activated on my phone line.  It diverts after only a few rings. Is there any way to increase the number of rings before the Call Diversion kicks in please ?
Thanks, Tim.
3 REPLIES 3
198kHz
Fixes: 41
Re: Number of rings before Call Divert no Answer
According to the instructions, it's a fixed 15 seconds.
Using Call Divert
There are three codes you can use, depending on what you want to do:
  • 21 diverts all calls
  • 61 diverts calls you don't answer in 15 seconds
  • 67 diverts calls when you're on another call
https://www.plus.net/help/phone/call-features/
BT technician (Retired)
RealAleMadrid
Aspiring Hero
Fixes: 61
@monolog99 The answer is in your other thread,  you didn't need to start this one.
https://community.plus.net/t5/Home-Phone/quot-This-call-is-being-diverted-quot-message/m-p/1875276#M...
monolog99
2 different questions.  Other thread is "Can Plus Net turn the announcement off" . This thread, "Can I change number of rings before divert kicks in".
