Number Porting
- Home Phone
- Number Porting
Number Porting
08-12-2013 2:00 PM
Is it possible to port in a telephone number, to an existing line which already has Plusnet service (Line Rental and FTTC) on it?
Example;
Line A (Plusnet), with FTTC
Line B (BT)
Can I transfer the number from Line B to Line A (ceasing line B in the process), and keep all services active as normal on Line A?
Thanks!
Example;
Line B (BT)
Thanks!
Message 1 of 2
(634 Views)
1 REPLY 1
Re: Number Porting
09-12-2013 1:07 PM
Yes, we should be able to do that for you though it will mean you'll go for a short while without broadband. Your best bet would be to give us a call and talk to the House Moves team - they'd be the best ones to get this sorted out for you.
Hope that helps.
Hope that helps.
Message 2 of 2
(231 Views)
