Number Blocking - Home Phone
craigbrass
Hello,
A relation of mine had broadband with you and I moved them to your home phone to save a little more and so they only get the one bill.
Anyway, to cut a long story short, the old provider was TalkTalk (not sure if mentioning them is against the rules here but I need to to make the point I am making) allowed her to block mobile calls from the line. She did this because her kids used to run up large bills calling mobiles before.
Anyway, when I asked PlusNet to do the same, I was told it isn't possible. Now I find this hard to believe considering the fact that her exchange is a country one and TalkTalk haven't unbundled it so they are using Wholesale Line Rental just like TalkTalk were before.
Can one of the team look into this because if you can do it, it would be a nice portal feature!
Best Regards,
Craig Brass
