Nuisance calls
Richard261
Nuisance calls
I am getting calls from BTW text between 5 and 10 times  a day. How do I get my 1572 to work on my landlines. Every time I try it says cannot  connect. Can somebody help please.
2 REPLIES 2
Fixes: 1,662
Re: Nuisance calls
@Richard261 - try 1572 again in an hour's time. The service wasn't active in our suppliers systems, but I've manually pushed that through, so you should be able to block numbers shortly. Let me know if you have any issues.
Fixes: 251
Re: Nuisance calls
... but if the number is BT's text to voice service, do you really want to block it?
If someone is mistakenly using your land line for sending SMS messages, surely the right approach is to correct their error?
